Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Complete beginner - merging 3 different angle jpegs to create 3d
1 REPLY 1
mark.wingfield
195 Views, 1 Reply
I am a first time user and just using for home projects. I have 3 pictures of a piece of furniture, from 3 angles, although not ideal as I don't have the image from the back. I cannot get any more images. However, I was still hopeful that this software may be able to extrapolate a 3d model from these 3 photos. Unfortunately, I have not found any descriptions in posts online regarding such extrapolations.
Is it possible and, if so, how?
Cheers
Mark
1 REPLY 1
Place the 3 images on appropriate canvases, scale and position as appropriate.
Start new sketches over the imaged to create your geometry.
File>Export and then Attach your *.f3d file (with the 3 images) here if you can't figure it out.
If you are looking for an auto-magical Easy Button solution - you won't find one in Fusion.
Technology Administrators
