Command Map / Learning Engine: Are archived projects taken into account?
lichtzeichenanlage
Advisor Advisor
Message 1 of 9
lichtzeichenanlage
Command map is kind of interesting. My question is, what's the source of the graph? Active projects, archived projects, logs?
Replies (8)
Message 2 of 9
TrippyLighting
It's probably based on logs.
It would have been nice if the installation on my mac succeeded ad if it dd not a more useful message was displayed  😕
@brianrepp could someone from the Research team check this thread out and provide some feedback on either of these questions/issues?
Message 3 of 9
lichtzeichenanlage
Ups.. wrong button. This is not a solution. Can the marker be removed?
Message 4 of 9
lichtzeichenanlage
Installation took forever on windows 10... First i stopped it, because it took so long, 2nd try I was (way) more patient and it worked out.
Message 5 of 9
TrippyLighting
Done!
Message 6 of 9
lichtzeichenanlage
Thanks!
Message 7 of 9
lichtzeichenanlage
Pull up...
Message 8 of 9
keqingsong
I've reached out to the team that worked on this plugin, and they will chime in sooner. In the meantime, I understand that the data is being generated based on you opting in on in-product analytics gathering when you first logged into Fusion 360. The option to opt-in or opt-out is found in the preferences (under your name) > Data Collection and Use.
Keqing Song
Autodesk Fusion Community Manager
Portland, Oregon, USA
Become an Autodesk Fusion Insider
Message 9 of 9
lichtzeichenanlage
Thanks for your feedback. Analytics data sounds reasonable, but I am not quite sure what to think about the data being kept so long and that it can be correlated with a user.
