Non-intuitive Joint limits
Am I alone in finding Joint Limits very non-intuitive?
I modelled a lever that rotates an axle, but want to set limits on the rotation. When I invoke "Edit Joint Limits" the window displays fields for Minimum and Maximum values, but relative to what? Where is the 0 deg position?
It's not possible to tick the Min alone; they must both be on or off. Ideally I'd like to be able to tick Min then rotate the axle to one limit (or set a meaningful value), then untick Min, tick Max, and rotate to the other limit. Then press OK.
How is it supposed to work?
I checked for previous queries about joint limits and found one from a person who had the same experience as me, from a few years ago. Somebody responded saying they would look into it, but nothing happened.
I found a couple of YouTube videos on the subject. They both basically ended up by setting limits by trial and error.
Does nobody else have this problem with setting the limits?
