Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Combine command doesn't work(failed to perform boolean operation)
6 REPLIES 6
steven_zhuQDRBU
407 Views, 6 Replies
I am creating a cam mechanism for some project, and I am creating some grooves on it because there would be a bar sliding back and forth. To create the grooves I stitched together a body. I have one groove but I want 6 of them all spaced evenly on the cam. I tried to create another body with the shape of the groove and cut it into the cylinder(combine command) but it didn't work. Can somebody please help me?
6 REPLIES 6
Circular Pattern the successful cut/s.
Might help….
do I have to unstitch the cutting tool
No, your pic shows one cut,
Now you circular Pattern that feature set, count 6.
Might help….
if I do that it just creates more faces it doesn't cut the shape
instead of doing a circular pattern for the feature I just unstitched everything and did a circular pattern for the groove. Then I stitched everything back together.
Ok, was checking your file.  Done now, now worries.
