Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Color components only to first level components
2 REPLIES 2
anderskoedj
289 Views, 2 Replies
Working with color components.
I have three components. Each component has a bunch of sub components. Is it possible to have each sub component colored the same way as my top component? So that I end up with only three colors?
2 REPLIES 2
g-andresen
in reply to: anderskoedj
NO
günther
jeff_strater
@anderskoedj - you cannot do this with Component Color Cycling, which is what we are assuming you are referring to.  However, you can do this manually, by just applying an Appearance to the top-level components (by dragging an appearance to the browser):
Jeff Strater
Engineering Director
Technology Administrators
