coincide moves the wrong point which i dont want to move
shivamagarwal2112
shivamagarwal2112
as I press coincide, for 2 distinctive points on two different curve to connect it moves the wrong curve which i want to be stationary.
TheCADWhisperer
Can you dimension location is space or Fix constrain the point you don't want to move?
Can you File>Export and then Attach your *.f3d file here?
chrisplyler
If nothing is constrained, and so it isn't obvious to Fusion which one to move, then the second point clicked moves to the first point clicked.
That's kind of not intuitive, since Fusion does the reverse in some other cases, such as when creating Joints. But that's how it works with the Coincident restraint.
