Coffee cups lid, loft tool's guide rail doesn't work
vpq310809
Message 1 of 19
vpq310809
So I want to create a coffee cup's lid that look like this right?
Since it has some weird curves, I want to create it at 0, 90, and 180 degree sketch of it and then use loft. Just by looking at my sketch you can see I manage to get the shape of the lid.
I also PRECISELY draw the guide rails with project to make sure the 3 guide rails intersect with the profile, yet somehow when I use loft it always say that either rail doesn't touch the profile (it does lol) or the tolerance problem. Even if it somehow work, there are hole in the loft too.
I HATE loft. I been stuck here for days now, please can someone help me?
Replies (18)
Message 2 of 19
g-andresen
please share the f3d file for reply
File > export > save as f3d on local drive >attach to post
günther
Message 3 of 19
davebYYPCU
Plain to see, the red blob means what it says, bottom rail is not connected to this profile HERE.
Trying to do too much in one go?
Step timeline.  Make your dimensions.  The file should update.
Might help...
Message 4 of 19
vpq310809
That is the f3d file
Message 5 of 19
vpq310809
My bad, I had attached the file on the comment section
Message 6 of 19
vpq310809
The thing is, the line DOES touch the line, and I did dimention it to the correct diameters and use project to make sure it touch
I'm sorry for forgetting to share the f3d file, it is in the comment section now, please help if you can.
Message 7 of 19
TheCADWhisperer
@vpq310809 wrote:
and I did dimention
@vpq310809
Most of your dimensions are missing.
Nothing in your design is precise.
Would you like to learn how to do this correctly with precise step-by-step instructions?
(view in My Videos)
Message 8 of 19
SaeedHamza
You did the right thing when you projected the profiles to make sure that the rails touch them. The only issue is that you chose the wrong loft for this, where you selected the solid loft, which is terrible for very thin profiles like these, so if you try the surface loft, it would work, and then you can turn it into a solid by either thickening it or boundaryfilling it then shelling it, both works great, but make sure to go for rounded thicken if you choose to thicken it and rounded shell as well for the other option. The thicken is easy for you to try, so I applied the second concept of boundaryfill+shell for you to checkout in the .f3d attached.
So if there was anything wrong at all, it was that some rails were not touching the profiles in some places, and that's because you didn't apply the projection of profiles concept everywhere, but the main pain you felt where loft wasn't working is mainly because of the solid loft behaviour, where the surface loft is much more forgiving, or I should say capable.
Please find attached a cleaned version of your file sketches with the above I mentioned applied.
Note: Your file needs alot of work, as your sketches are poorly created and not defined, but it will do for now.
Saeed Hamza
Message 9 of 19
vpq310809
Do we really need dimension for this type of design? I know it will be helpful if I have them but the thing is this is practice for school so the blueprint only give me a limit set of dimensions. However I'm pretty sure I got the lenght of each line and diameters correctly, I did project, and normally that's enough for the guide rail to connect to the profile yet this time it doesn't and I don't know why. I would be really happy if you can show me an instruction for this type of design.
Spoiler
Message 10 of 19
vpq310809
Thanks for the reply, it was really helpful. However can you explain to me what you mean when you said "the rails were not touching the profiles in some places, and that's because you didn't apply the projection of profiles concept everywhere"? Because I did project the line and points that the rail will connect to the profile at. Do you mean I need to project the entire profile? As for the sketch being poorly created and not defined, it is because this is a practice test with time limit so I just rush it as quick as I can. Will it matter at all as long as I get the shape?
Message 11 of 19
TheCADWhisperer
@vpq310809
Sketch1
(view in My Videos)
Message 12 of 19
SaeedHamza
It was wrong to say "rails were not touching the profiles" by me, what I meant was that the rail wasn't constrained to the profile projection, like where it's shown in the screenshot below.
Also, no, you don't need to project the whole profile, just the line or point where the rail needs to touch it.
Saeed Hamza
Message 13 of 19
TheCADWhisperer
@vpq310809
Having taught CAD for over 30 years I have always observed that it is much faster (and easier) to do it right than to do it haphazzardly.
(view in My Videos)
Message 14 of 19
vpq310809
Thanks for the advice. I would love to see how similar your final design will be compare to the picture that I wanted if you don't mind.
Message 15 of 19
TheCADWhisperer
@vpq310809
We follow a logical set of steps to create the geometry and keep everything simple.
(view in My Videos)
Message 16 of 19
TheCADWhisperer
Complete to this step and then Attach your progress file here.
(view in My Videos)
We will then complete the final details...
Message 17 of 19
TheCADWhisperer
@vpq310809
In my experience - high quality work is often the fastest and the fastest is often the highest quality.
(view in My Videos)
Message 18 of 19
vpq310809
I didn’t expect this much of an enthusiasm response, I thought you would only help me with the loft tool not redrawing the entire thing so I greatly appreciate the support. One of the main reason why my dimension's number was a bit weird is because of this.
This is the blueprint for the lid I want to make. It’s from a 2018 secondary CAD provincial competition, so they purposely gave just enough dimensions to create the shape. Some dimensions are a bit unusual, and some aren’t provided at all (I’m using the medium size/parameters). That’s why it’s hard to create the sketch in the first place.
Message 19 of 19
lauri_barnhart
Hello @vpq310809,
It looks like you have received a lot of advice on this thread. Did any of the replies by @g-andresen, @davebYYPCU, @TheCADWhisperer or @SaeedHamza answer your question? If so, consider clicking on 'Accept Solution' on the post(s) that helped you with your question.
If you are still needing more help, please share an update here. The community will be happy to jump in and suggest more steps to help you get where you need to be.
Best,
Lauri | Community Manager
