cloud render bug
cloud render bug
aliobidi
Message 1 of 16
cloud render bug
aliobidi
Hi ,
I don't know if my post in the right section .. but ,
there is a material bug on cloud render .. when you render it will show as white
but if you render it in local will be fine
I try the same material on some models , but same result
this material is " Leather -Matte (Black)"
Replies (15)
Message 2 of 16
Steven_Gao
Sorry for I didn't find your mentioned material - Leather -Matte (Black). Can you tell me where is the location of this material?
Steven
Steven Gao
Fusion & Inventor Quality Assurance
https://www.autodesk.com/campaigns/fusion-360/insider-program
Message 3 of 16
aliobidi
Message 4 of 16
TrippyLighting
@Steven_Gao There are several such material that differ between the cloud and canvas/local render.
Message 5 of 16
laughingcreek
@Steven_Gao - it's an appearance.  not in the materials.
Message 6 of 16
Steven_Gao
Thank you, guys! I got the appearance and confirmed this problem. I have logged an internal defect(FUS-99359) to track it now.
@, it would be great if you can provide the detailed appearance list of your mentioned which have the cloud rendering issue.
Steven
Steven Gao
Message 7 of 16
wmhazzard
A simple forum search shows three posts about the exact same problem as the OP, as far back as 2018.
Here is one that is reported as a bug.
https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&...
Message 8 of 16
laughingcreek
whoa! this list goes back to 2015!
Message 9 of 16
Steven_Gao
OK, thanks all! I added the additional information to the defect too.
Steven Gao
Message 10 of 16
TrippyLighting
Here is the material I came across in recent work.
It is the Aluminum Brushed Radial. It renders nicely in the canvas and local render but is not visible in the cloud render.
It is also not visible in the web viewer.
Message 11 of 16
aliobidi
so let's be more specific .. there is (appearance and physical ) and both are materials
Message 12 of 16
laughingcreek
nope!
the physical material is used for the physics properties, lake mass.
appearance is only the way it looks and has no bearing on things like mass.
you can apply both to the same object, but the material will be used for mass
and the black leather you pointed out is only found under appearances, not material, which is why @Steven_Gao couldn't find it initially.
Message 13 of 16
Steven_Gao
@TrippyLighting I checked the Aluminum Brushed Radial. I saw it has the display issue via web viewer, but I can see the result with cloud rendering. Please refer to the attached pictures.
Steven
Steven Gao
Message 14 of 16
TrippyLighting
Not the case here on my side. These were just rendered. I can share the file privately.
Canvas render:
Cloud Render:
Message 15 of 16
Steven_Gao
Yes, it seems there is a problem for your dataset with cloud rendering. Please help to share your dataset to me(mingwei.gao@autodesk.com) and I can add it into the above defect to let development team to take a look.
Steven
Steven Gao
Message 16 of 16
TrippyLighting
I've been digging into this a little deeper.
The material in question was originally "Steel - Brushed Radial Overlap". I changed the color to a much lighter grey so it would look more like machined Aluminum. Then I called it "Aluminum - Brushed radial Overlap" and saved it to "My Appearances"
Interestingly enough, in My Appearances it shows up in the Metal->Steel" folder.
So in the image below the torus and upper left box are Aluminum - Brushed Radial.
The upper right box has the Aluminum - Brushed Radial Overlap from My Materials applied to it.
The lower right box has the Steel - Brushed Radial Overlap applied to it.
In essence it's the Steel material that poses the problem, not the ALuminum.
Model is attached.
