Close Gaps in Complex Solid
適用対象外
605件の閲覧回数
5件の返信
メッセージ1/6
適用対象外
I tried selecting one of the internal faces and extruding as a join to close the gap, but I get an error. How can I close this gap? The solid is from a sweeped surface along a coil. The gap is due to the fact that I had to scale the surface to .99 in height so that it would not intersect itself as the sweep operation will not work with self intersection. Thanks!
0 件のいいね
解決済み
606件の閲覧回数
5件の返信
返信 (5)
メッセージ2/6
TrippyLighting
Can you share your design (public link to it from the data panel)?
0 件のいいね
メッセージ3/6
適用対象外
Sure thing
https://a360.co/3b7Cnz7
I also have the same issue here:
https://a360.co/2y3GxZS
0 件のいいね
メッセージ4/6
MoshiurRashid
解決済み
Hi
Thanks for posting. I've done analysis of the problem and short out the reason. (But cant solve it because you DID NOT capture the design history)
The reason is, when you sweep a profile along a threaded path, it goes a helical way. So, as you created the profile, the corners created a gap between (because pitch value is little bit high)
My suggestion is, you create your profile like this:
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
0 件のいいね
メッセージ5/6
TrippyLighting
If you can re-create the model with the timeline enabled I'll take a look at it.
0 件のいいね
メッセージ6/6
TheCADWhisperer
Is there a logical reason that you are not capturing your Design History?
I recommend that you start over with Capture Design History turned on.
I recommend that you fully define your sketches.
0 件のいいね
