Circular Ramp
Circular Ramp
glenn.mause
Message 1 of 9
Circular Ramp
glenn.mause
Hi, I want to intersect between two platform with a ramp following a quarter circle.
This is how the platforms are positioned from the side:
And from the top:
The ramp should follow a path like this:
And connect both platforms.
I looked into using coils, but apparently you can only use squares with those, but I would need rectangles.
Replies (8)
Message 2 of 9
whittakerdw
Maybe I am not understand exactly what you're getting at, but why not extrude the circle you have by trimming the unnecessary sides and using lines or arcs to form the ramp to the desired size. This is what I was picturing.
Or if you were meaning an arc shape instead:
I hope this helps. If this wasn't what you were looking for then I may need a little extra explaining.
Message 3 of 9
mavigogun
I Sketched 2 Rectangles > used a Spline to connect them to guide the ramp >  adjusted the Spline handles > moved one Rectangle and Spline End Point above the Sketch Plane > ended Sketch > Patched both Rectangles > hid the Sketch > Lofted with Tangency from Rectangle A to Rectangle B using the Spline as a guide rail.   See attached image.Ramp.JPG
Message 4 of 9
whittakerdw
@mavigogun, I figured there was a great possibility I was misunderstanding. That looks good though.
Message 5 of 9
etfrench
A coil would be the easiest way.  Create the coil using a square profile, then Press Pull one side to make it rectangular.
ETFrench
Message 6 of 9
HughesTooling
@glenn.mause How about the attached file. You didn't specify the height of the platforms, next time you need help export the f3d and attach.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 9
mavigogun
Could you demonstrate that?   How would the lead in-out to the ramps be effectuated using Coil.    To what degree can you use Coil to hit an exact elevation at any given point of the arc?
Message 8 of 9
etfrench
Here you go.  Note: No sketches were harmed in this screencastSmiley Happy
Extruding the end faces will create the landings.
ETFrench
Message 9 of 9
mavigogun
Nice demo of the tool- I learned stuff.   That said, imagine driving that ramp- the lack of transition to the landings would be excitement for a jacked up 4x4, and no fun slow or at speed for urban vehicles.   Actually, a functional ramp would benefit from a camber  for its length, too.
