I need a flat circularly inclining plane. Basically a coil with 1 revolution, but instead of a square, a very thin rectangle. I know my inner diameter(3), outer diameter(26) and the inclination after 1 revolution(1).
I thought I could start with that square coil, use one of the edges for a 'plane along path' and draw a rectangle on that.(I projected some other object to get the right rectangle size).
Next, just use the sweep tool to get the surface that I need. Unfortunately, the sweep tool is giving me some unexpected results:
This gets me in the ballpark, but I can't get it exact. I tried messing with the sweep settings, and I can get close, but what's the point of CAD if you can't get it exact? 🙂
How do I achieve this?
