Cannot export Sheet Metal Flat Pattern as DXF
andrewtothcollege
andrewtothcollege
Error: There was an unexpected problem with exporting the flat pattern as a DXF file.
This is not useful feedback.
I am trying to export my sheetmetal design, which has bends, engravings, and holes for use with an online service like OSHcut.
Some of the holes are tapped using the Hole (H) tool.
Even if I suppress all the emboss, I continue to get the error
Could you help me find a way to export it with the bends? (The holes won't be tapped by the service, but I would like them cut the holes to size so I can just go in with a tap instead of me using a drill + tap)
dsouzasujay
Hi @andrewtothcollege ,
Can you please follow steps mentioned in the below link to export the DXF from a Sheet Metal Flat Pattern
LINK
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
