Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Changing units in UI but dimensions in viewport don't change.
4 REPLIES 4
TrippyLighting
427 Views, 4 Replies
With an opend sketch I changed the Units from mm into inch hoping the dimensions would now be displayed in inch. Did not work!
I'd consider tis at least unexpected behavior.
Heres a link to a video demo on dropbox
Peter Doering
4 REPLIES 4
I'm testing this on my PC with Build 2.0.1351 and I'm having some difficulties reproducing the issue. I notice the dimensions update in real time as soon as the units are edited.
Could you confirm which OS and which build number you are using? You can check the Help > About Fusion 360 menu to verify the build number.
One quick work around may be to exit by selecting the Finish Sketch command in the ribbon and then re-edit the sketch to see if this forces the units to refresh.
Please let me know if you have any questeion.
Nathan Chandler
Principal Specialist
Peter Doering
brucehuang
in reply to: TrippyLighting
Hi, I'm a developer of Fusion team. Thanks a lot for reporting this issue. I can reproduce it in 2.0.1351 on OS Win7 64. It seems the issue only happens in a parametric design. I have logged a bug (FUS-15537) for corresponding dev, and it will be fixed in next release.
TrippyLighting
in reply to: brucehuang
Thanks for the feedback!
Peter Doering
