Changing diameter in multiple holes.
litodrums
litodrums
I have a plate with 64 holes that need the diameter to be increased by 0.005" larger.
How do I change all 64 holes simultaneously.  They are all set currently at 0.500"
I have enclosed a file of my project.
Thank you very much for your help
litodrums
This post should move to Support. Thank you
jahnj0584
If you did the CAD properly, change the driving .500 dim to .505. The easiest thing would be to run a -.0025 radial offset at the controller. 2nd option is do -.0025 stock to leave in your CAM and repost.
TheCADWhisperer
@litodrums
No.
Did you read the guidelines over there?
That forum is for bugs.
This post is in the correct location.
TheCADWhisperer
@litodrums wrote:
I have a plate with 64 holes ...
Is there a logical reason why you created 64 Hole features rather than one Pattern?
Did you intend for the hole locations to be symmetrical on the plate?
Edit one hole feature - edits all holes in the pattern...
See the Attached file.
g-andresen
here´s a pattern screencast
günther
