Changing Axis while importing from meshmixer to fusion.
Message 1 of 11
Hi.
I am trying to import stl files created or edited in meshmixer into fusión 360. but when i use the move object i get a different axis in fusión.
How can i use the same axis of movement as in meshmixer.
Here are the pictures of the same solid in both software with their traslation axis.
Thanks in advance.
Replies (10)
Message 2 of 11
daniel_lyall
In preferences under your name you can change from Y up to Z up, change that see if it helps.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 3 of 11
Hi. Thanks for your fast reply.
changing z-up didn´t solve the issue. As you can see, the problem is not that the program changes y and z axes. The problem is that it is at 45º of every axis with respect meshmixer.
Thanks again
Message 4 of 11
daniel_lyall
You can move where the move tool sits, meshmixer will be by default Z up or Y up if it's coming in at a 45 degree angle are you sure its squire in meshmixer, when you first bring it into fusion if you position it then its captured where it sits,
Other than that can you do a screencast of the steps you do from meshmixer to fusion. as if it is squire in meshmixer then coming into fusion at a 45 degree angle that's a bug.
Daniel Lyall
The Big Boss
Mach3 User
Message 5 of 11
Hi, thank you for your interest.
Here is a streamline of this strange behaviour , as you see bunny doesn´t get affected , but the cilinder does.
This doesn´t happend only with fusion 360. I have used other software before like 123Ddesign; and when i change from one software to the other solids just change axes of movement. so it may be something i am doing wrong. but what???
Thanks again.
Message 6 of 11
daniel_lyall
It's coming how it was set so what you are seeing is correct, if you wont something squire to a plane you have to do it right from the start squire to a plane.
Daniel Lyall
The Big Boss
Mach3 User
Message 7 of 11
Is there a way that after moving the object into a specific postion in meshmixer and then exporting it to fusion 360 mantaining the same axes of movement as in meshmixer ???
Message 8 of 11
Message 9 of 11
TrippyLighting
Do NOT ask the same question in two different ancient thread.
Please create your own thread and explain what the overall goal of you design is.
In the image you show it looks like you are trying to thicken a .stl body completely beyond reasonable limits.
Message 10 of 11
my aim is to produce ankle foot orthotic (afo) for the human foot but when I enter the parameter values by trying the paths that I watched https://www.youtube.com/watch?v=XrgXys3NLY4 in the training videos, I get extremely large shells like the picture. I can not adjust the gap of the medical device I want to make, and when I write 2 mm higher than the standard offset settings for the thickness, it becomes an extremely large object like the picture. rejoice if you share your worthiness with me
Message 11 of 11
TrippyLighting
I'd take this question to the Meshmixer forum.
If your .stl models have the same or even higher density models as shown in that video, which would not be uncommon, you will run against a hard stop using that in Fusion 360.
