Change view to construction plane
When I create a construction plane through an edge of a solid, the edge does not seem to be part of the plane. I can not lock to it or use the edge to constrain other elements in the plane.
TheCADWhisperer
While in Sketch are you using the Project Geometry tool?
No. I will try projecting the edge to the plane. Thanks (if it works). No, really, thanks.
