Change of parameters of generated gear (helical gear+) afterwards?
edwinTYE62
edwinTYE62
Community Visitor
Community Visitor
I have modelled a part containing a gear (using the add-in Helical Gear+).
After I have tested it, I had to change the gear a bit. But I couldn't find a way to change the (parameters) of the gear so that all changes after the gear generation would also ripple down. So I had to redesign most of the part again (location of gear, holes in it, text in in, etc).
Is there a way to more easily change the gear a bit, without having to redesign everything after the gear was introducted the design?
davebYYPCU
Need a file with your data,
should be no problem,
are the sketches fully defined?
dependencies make sense?
P.IM
I would love to know the answer to this. Using Helical Gear Generator, myself. Hoping the process would be similar.
wmhazzard
As far as I know, you can not go back and edit the dialog box of the helical gear generator, it is once and done. You can change some parameters in Fusion but there are none for tooth profile.
