Change Name in Drawing Header
ch_schelbert
ch_schelbert
In my drawings i have the wrong default name
ist shold be "Christian Schelbert" (as it's in my Autodesk profil) insead of "Christian Müller"
thx4help
Drewpan
Can you change it in the profile settings?
Cheers
Andrew
ch_schelbert
you mean my online Autodesk Profile?
I changed that one
jhackney1972
If you select your Avatar, in the upper right corner of the Fusion app, you can select to see your Profile.  This profile is the one being used to populate your drawing Title Block.  If it does not match, then I would suggest that you have two Autodesk IDs and I would log out of Fusion, same location, and log in using the account that you show having your correct name.
John Hackney, Retired
ch_schelbert
log out - log in
standart IT support advice
still working at its best
