Best resources to start with
justinking30
Message 1 of 16
justinking30
I am a former boilermaker/welder who has recently sat down behind a computer and is taking up the admin side of the business. We manufacture a lot of structural steel items for various clients throughout the telecommunications industry.
I have a basic understanding of fusion and can draw simple components. I haven't yet dipped my toe into trying anything to complicated at this point, but I am keen to give it a shot.
We have our own plasma cutter so a lot of the drawings we need to produce are just copying ''For Construction'' drawings that have been supplied by our clients - creating DXFs etc so we can then go and cut the flat plate, for us then to either weld members to the plates or fold and form them.
Is there a way to draw a folded plate that has been bent multiple times to form an arc with folded ends to form the collar below?
Every time I tray to draw this I run into errors because the arcs run into each other.
Also is there a database of steel member drawings or DXFs that I can import when trying to draw different designs? I.E RHS/SHS/CHS/PFC members in various sizes? I tried to draw a platform and thought there had to be an easier way, drawing up each different sized steel member became tiresome.
I guess I can make my own database of DXF drawings and locally save them and import as necessary? surely this already exists though.
What I am after are some resources that can help with the particular type of work we do, I haven't seen a lot of examples available on the internet or in the self learning section.
Any help is appreciated.
Replies (15)
Message 2 of 16
Drewpan
If you are working with plate and sheet metal then maybe using the sheet metal tools is what you need. This allows
you to design bodies that can be laid out flat at the click of a button. It is possible to create a shape and convert it
if you have drawn it properly, but maybe creating it within a set of sheet metal rules will work better for you. There
are a number of tutorials about the sheet metal tools in the self paced learning but maybe you want some of the
more in depth learning from AutoDesk University.
I am not 100% sure what you are asking for with the different sized steel members but it sounds like what you need
is a combination of the Configurations tools, which are relatively new, and setting up a whole bunch of parameters
to differentiate each configuration. This would allow you to set up several basic shapes and then just input the
parameters to get them the correct size. There may be a bunch of work setting up your configuration table but then
you should just be able to pick items from it as you need them.
Everyone's business is different so there probably is not any specific tools for your business, but that being said
there is much overlap with many businesses so there are many tools available to choose from. Sometimes it is just
about finding ones that work for you.
Cheers
Andrew
Message 3 of 16
TheCADWhisperer
Let's take one problem at a time to get started.
@justinking30
Can you File>Export your *.f3d file of your attempt to your local drive and then Attach it here to a Reply?
Message 4 of 16
TrippyLighting
I would stay miles away from importing DXF files.
Structural steel profiles are trivial to model with the native in Fusion.
Other, more mature CAD software often comes with such libraries for structural steel and all sorts of materials.
Fusion 360 does not.
Message 5 of 16
Warmingup1953
Re Standard .dxfs for sections where are you located? Australia?
https://www.cad-steel.info/steel-sections/universal-columns
Message 6 of 16
Warmingup1953
A better screen capture of the Drawing?
Message 7 of 16
wersy
Does it look something like this?
Message 8 of 16
jhackney1972
The site you give is an excellent source of steel sections.  One correction to your post, the downloads are DWG files not DXF files.  You would download them, upload them to the Data Panel and they will convert to a Direct Model automatically. You can them open them, Capture Design History, and from there do as you wish.
John Hackney, Retired
Message 9 of 16
BespokeMetal
Observer
Observer
Yes I am in Australia. Thank you I knew something would be out there!
I appear to have logged in with my employers login..
Message 10 of 16
BespokeMetal
Observer
Observer
Yes that is it! Thank you I have downloaded that file and will have a look when I get into work!
Appreciate the help.
Message 11 of 16
justinking30
Unfortunately I don't have a lot of options, My employer has chosen Fusion 360.
Are you saying using fusion for drawing steel structures isn't possible or just painful?
Message 12 of 16
justinking30
Ok so I have had a look at your model. and I see the way you have done this.
Is there anyway to turn the formed plate into a flat pattern the way you have constructed it? I had tried this method of drawing it previously and hit a wall at that point.
Message 13 of 16
justinking30
This is the error I am referring to:
Message 14 of 16
Drewpan
Well we are advanced enough Down Under to use the ISO Metric System.
Cheers
Andrew
Message 15 of 16
davebYYPCU
No.  The body is not a Sheetmetal body.
Will flat pattern if you were to Convert it to Sheet metal.
Might help….
Message 16 of 16
BespokeMetal
Observer
Observer
Perfect, thank you. I didn't know that was a feature.
