Change line type to solid when including sketch in 2D drawing
I need to add lines and dimensions in the 2d drawing environment.
I have been advised by Fusion rep to include sketch from model in the 2d drawing but I need that line to be solid not dashed.
Is there a way to change line type?
There seems to be very few options in the 2d environment which kind of makes the modelling side of the software useless if you can't create 2d drawings for suppliers.
wmhazzard
No, sketch lines are only dashed, they can't be made solid.
pavmed
You can make bodies from your sketch if you need solid lines.
It's not a solution but possible workaround.
Could you share what geometry you need in drawing which you have to get from sketch and not from your model?
