Modifying skecth does not change solid
I work with Fusion 360When I ceate a new Design and that I make an extrusion or a revoltion from the sketch if I modify the sketch the construction follows and modify too.
But whenerver I open an existing Design from format .stp, .CATPart, etc if I modify a solid from the sketch the modifications does not follow.
The difference being that when I make a solid it creates a Body AND a Revolve/Extrude ect. From what I understand it breaks the links between the sketch and the solid. Is there a way to keep the sketch and solid linked?
I also lose the Design History bar when opening a .stp.
Steed
g-andresen
 1. when you open a step import, the design history is not activated > you must do it.
2. In the absence of history, there is also no dependence between sketch and bodies.
günther
g-andresen
Sorry, wrong thread!
Please ignore!
günther
Thank you very much for your help!
