Change angle of part of body
nopeaderia
Observer Observer
nopeaderia
Observer
Observer
I have found this project on printables and would like to change the angle of the upper body where the camera sits. The whole thing has been designed around the camera, with the camera already at the desired angle from the start.
I've tried changing the angle of the camera itself, but haven't even managed to do that. Unfortunately I also didn't find any tutorials or so, because it seems to be a bit a special case.
Any help or tips of how to go about it are greatly appreciated!
This is the canopy:
And this is the camera around which it was designed:
davebYYPCU
To what angle?
When you know that, change it in the Camera file.
The mount file, - camera position will update, and
then the camera mount body construction might update correctly.
Might help....
nopeaderia
Observer
Observer
Thanks a lot for your tips!
After reading what you suggested, I've tried to adjust the angle but couldn't figure out what you mean by Camera file. I've experimented more and finally found out that I can adjust the initial position when I mark the DJI_O3_camera_naked object and right-click and select `Edit Initial Position`. There I can change the angle and then the construction updates and I just had to fix some minor things.
I'm not sure if that is the best way to do it, but I finally got it to work!
Thank you!
