Chamfer stop on edge
christofferW528U
Message 1 of 13
christofferW528U
Hi. im working in the furniture industri and often want to stop a chamfer on a specifik point.
Looking for the best way to do this its slowing my workflow very mutch to try combine/split and so on.
sweep not working very good either.
Cant there be a feture that lets on place a point on edge to stop the chamfer or something like that?
Best regards
Christoffer
Replies (12)
Message 2 of 13
jeff_strater
you are correct in that today, there is no way to do a "partial chamfer".  Manually doing it with sweep is the only real workaround, so if that is not working for you, you'll have to do something even more manual, such as a loft.
Jeff Strater
Engineering Director
Message 3 of 13
christofferW528U
Hi thanks for quick reply.
i have looked in forums and so on.
And for what i can understand this has been reqested like several years ago.
Is there a plan to adress this problem in the future?
ill look in too the loft function but i guess it wont work as i want.
Best Regards
Christoffer Horndahl
Message 4 of 13
davebYYPCU
Don’t understand why Sweep fails.
Straight chamfers can be Extrude > Cut - Distance, or to a point.
Might help....
Message 5 of 13
christofferW528U
I will give an example.
i have 2 diffrent components like a leg that are connected to a border on a table, the chamfer must stop where they are connected and continue along the boarder seamlessly.
i have done this before joining components together but it messes upp the cadfile and creates problems.
maybe i just havent got the correct workflow for it?
Best Regards
Christoffer
Message 6 of 13
davebYYPCU
Like this?  Edit the 3rd extrude for the settings.
Might help.....
Message 7 of 13
christofferW528U
Wuld love to have this as a main feture in fusion.
Message 8 of 13
christofferW528U
just saw the attached file. thx
Message 9 of 13
christofferW528U
thx.
if u have time i wuld love a short screencast on it for future referance.
@davebYYPCU
Message 10 of 13
davebYYPCU
There are a few ways to do this sort of thing, probably not the way I would do it, but as you stated you had the 2 components in existence, I just followed your lead.
I made the components, extruded their sketches, rail has inbuilt chamfer in the sketch.
For the yellow component, I added the triangle to the sketch,
Extrude cut, select from the chamfer face of the rail to start from, and take it all the way down.
Screencast and I don't get on.
Might help....
Message 11 of 13
barry9UDQ6
The chamfer tool could be used perfectly if the 2 solids were joined. Why not model up as 1 solid, chamfer, and split up after?
Message 12 of 13
christofferW528U
This will be the way to do it from now on iguess.
The example i provided isent for every time i have to chamfer.
Its a lot of models and some times i dont know before i start, if and were a model needs to be chamferd.
Anyway thx for taking the time.
Best regards
Christoffer
Message 13 of 13
christofferW528U
Thats a solution that best culd be used if one knows from start every chamfer.
i have tried it multiple times after a complete assembly and its giving me lots of bugs with multiple bodies that cant be delited and so on.
Best regards
Christoffer
