Chamfer on a shaft
Chamfer on a shaft
nstevelmans
Chamfer on a shaft
nstevelmans
Hello Fusion,
can i make a chamfer on a shafts end, i cannot select the distance direction
when i select angle and distance.
see also the picture.
PhilProcarioJr
Selecting the distance direction is not currently possible in Fusion 360, the work around is to do a revolved cut at the end of the cylinder.
I added a feature request here: vote for it if you like so we can get this into the software soon.
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/being-able-to-switch-distance-directi...
Phil Procario Jr.
Owner, Laser & CNC Creations
nstevelmans
I will make the work around.
The chamfer command is now useless when it comes to designing a Shaft, so it will be a good idea to make the software and de chamfer command more mature, in a new release
