Chamfer- Distance and angle
dpar15
dpar15
Is there a way to choose the direction the distance is measured? Almost all the dwg I receive measure the distance along the length of the shaft not dia. The chamfer command wants the distance on axes of the dia. I have to trig the distance to put in the command.
Be as humble as your skills require you be.
PhilProcarioJr
Does this setting do what you want?
Phil Procario Jr.
Owner, Laser & CNC Creations
dpar15
That's what I'm using. There is no way to choose the direction the distance is measured.
dpar15
I need the distance to measurethis way.
TrippyLighting
Yep, this seems to be an unnecessary limitation. I'd add an idea to the Idea Station. It will get my vote!
PhilProcarioJr
I added this to the idea station as this is something I need also. dpar15 thanks for pointing this out.
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/being-able-to-switch-distance-directi...
Phil Procario Jr.
