Chamfer bug
Chamfer bug
daniel_lyall
Mentor Mentor
Chamfer bug
daniel_lyall
As can be seen in the vid the chamfer goes a bit wrong when setting it to 30 degrees using angle & distances.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
laughingcreek
this is a problem with chamfer that I've seen discussed in the past.  fusion isn't measuring the angle from the same surface for all the edges.  it doesn't do a very good job of guessing which edge you want to measure from, and doesn't provide a way to change it manually.  one way to ensure the chamfer is applied the same to all the holes would be to just do it to one hole, and circular pattern it to the others.  You can actually do this with all the holes and features on this part, which generally makes sketching easier.
daniel_lyall
That does work I would rather it got fixed I am getting tired of workarounds, thanks for the suggestion though, I will be redoing the model so it is propper with using the hole tool I just need to get it done, second to last part for my robot.
Daniel Lyall
The Big Boss
Mach3 User
