Centerlines
Centerlines
elee
Message 1 of 17
Centerlines
elee
If you are creating a 3 view drawing from a model and you have a partial arc on your front view, how do you create the centerline for that arc on the right side view?
Replies (16)
Message 2 of 17
Drewpan
How did you create the Centreline for the Top view? It should work exactly
the same way. One other way might be with a Section Cut line?
Cheers
Andrew
Message 3 of 17
jhackney1972
You can create a sketch in the model to show as the center line.  In the drawing make the sketch visible and change the line type to Center 2.  It is not real efficient but it gets the job done.
John Hackney, Retired
Message 4 of 17
John_Wright
I suggest you try your own advice and see how it works out....
Message 5 of 17
user015M86Y
@elee ,
I use Center Mark Pattern
Message 6 of 17
elee
I just tried this this morning and it didn't quite work.  Looks fine on the 3D model but I don't see it on the drawing.  It is sketch #4 and you can see the line on the model, but sketch #4 is grayed out on the drawing and I don't see the little warning symbol at the top of the page to show it isn't sinc'd with my model.
Message 7 of 17
John_Wright
Click on the "eye" circled in the image above 🙂
Message 8 of 17
elee
I had already tried that, didn't change anything.
Message 9 of 17
John_Wright
This seems odd.
Can you share the project?
Message 10 of 17
elee
Message 11 of 17
John_Wright
Thanks, can confirm that the I see the problem too.
Is the sketch a 3D sketch? The geometry is not drawn on the sketch plane to this may be causing the issue. @ClintBrown3D can you confirm a 3D sketch would cause this please?
If you redraw a sketch on your construction plane in the middle it works 🙂
Message 12 of 17
ClintBrown3D
Yes, 3D sketch will not show.
Also, using the center mark pattern as suggested above will give you a nicer center mark on the partial arc
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 13 of 17
elee
Ok, so I now have the line, but I can't figure out how to change it to a Center2 line like your example.  I click on document settings to open that tool panel and then click on the second tab and change the linetype but I don't see how to designate which line I'm trying to change.
Message 14 of 17
ClintBrown3D
Clint Brown
Message 15 of 17
elee
Thank you.
Message 16 of 17
elee
Clint, how did you change the small center mark on the front view to long centerlines?
Message 17 of 17
ClintBrown3D
Clint Brown
