Centerline and mirroring
Rose11122
Rose11122
I placed a centerline horizontally in the middle. How do I align the 13mm line so it's in the middle of the centerline?
I want to draw a shape on this rectangular surface. How do I mirror the half shape that I drew? Some of the lines are still blue, how do I lock this sketch so I can extrude it later?
New to Fusion, so any help is appreciated!
g-andresen
Create a coincident constraint > centre point 13mm line (shift + hold + select centre point) to the centre line
günther
Rose11122
Thank you! How do I add a midpoint of the 13mm line?
g-andresen
watch added screencast >#2
günther
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation and also some of the
Self-Paced Learning to help you to learn fusion faster and better. They can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of what you want to achieve
and what the problem is. You can create a file to export like this:
Time spent on the tutorials and self paced learning will not be wasted. Also check out the three RULES that are pinned to the forum for further guidance.
Cheers
Andrew
