Varying- depth, semicircle at an angle
pblack11
Observer Observer
pblack11
Observer
Observer
I have two sketch faces I need to extrude to each other. I am not sure how to do this.
The bottom of this trapezoid shape is a semicircle shape, but the depth is at an angle, it gets smaller as it goes outward towards the top sketch.
-issue 1: The extrude feature only allows for 90 degrees.
-issue 2: I am new to even using this software.
-issue 3: I am kind of in a time crunch.
Please let me know how someone would go about this.
laughingcreek
sounds more like a loft.  can you export your model as an .f3d and attach?
davebYYPCU
Start a new body.
Use solid Loft. Select the region above the blue curves at each end.
Might help….
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
pblack11
Observer
Observer
thanks this worked perfectly I didn't know about this feature.
