Center a PVC fitting and create two components
I'm creating a PVC frame, and I would like to create a couple pieces based on the design, so if I change dimensions of another part, it should automatically update.  Basically, I want to center a T-fitting between two 45 degree fittings, then connect the three with PVC pipe.
So I would like to do two things:
1) Center the tee between the fittings
2) Create two pipes between the tee and fittings, based on the centered tee.
Thanks!
davebYYPCU
Straight or bent pipe?
will need your file, to do better than ask you questions...
Straight.  I need to center the tee along the axis of the two 45's, maybe that's a better way to put it.  how do I post the file? Can I share it from fusion 360, or do I have to export?
laughingcreek
exporting is better. if you share it, folks will get what ever is current at that moment.  meaning you may be half way into trying something, etc.  downloading a fixed model and trying to figure out what was wrong is annoying also.
export from the file menu
file-export as .f3d file
I'm assuming you mean .f3z, I don't see an option for f3d.  It's attached. Thanks in advance for any help you can give, I appreciate it.
davebYYPCU
You already have the midplane, I dragged it to a size I can see.
Roll Timeline back between the Tee and the Plane,
Make sketch on that plane.  I got an origin point showed up in the sketch on centre of the outside pipe.
If that doesn't work for you, project a circle to the sketch from the 45 bend face.
Finish Sketch.
Make a Joint between the Centre point of the long tee barrel, and the origin / centre point in the sketch.
When the height of any of the frame changes, the Tee will follow.
Might help...
TIL about resizing construction planes... didn't know about that.  Thanks!  I got it from there.  I thought the midplane construction plane didn't get created because it was so small.
Thanks again.
