Cant select threaded hole for bolt conector simulation.
VertexE
VertexE
HI there.
I have 2 components that I want to connect with a threaded bolt in the simulation environment. The issue I'm having is I can select the bolt head location but I'm not getting any options to select the hole threads. I want the 2 bolts to go on either side.
Can someone help me with this?
Here is my design https://a360.co/3kCWoEH
Thank you
Joshua.
TheCADWhisperer
Do not use Modeled threaded holes in analysis.
And these threads are not even modeled correctly.
BTW - Using the BORN Technique this design could be done with 2 (maybe 3) simple (fully defined) sketches.
VertexE
Thankyou, that fixed it.
Why do you think the thread didn't model correctly?
Regards, Joshua.
TheCADWhisperer
If I get time - I will remodel from scratch using the BORN Technique.
VertexE
Thanks, I'm yet to optimise my sketch technique, mostly about when to finish a sketch and when to keep going.
What does BORN stand for?
EDIT: just seen your youtube video on the BORN technique.
