cant get this shape. How to do that on fusion?
3 REPLIES 3
560 Views, 3 Replies
block done in mayablock done in maya
hey guys, this is my firt post here, so hi everyone...
So....i am a very new user and i was started to work on fusion on monday, but i have some knowege in another 3d softwares
I modelated this block shape here on maya, and after that i imported the model to fusion, just like reference, im thought that i wil gonna make a better version of this shape here in fusion...but, im been like...2 days trying to get this shape whitout any good results, all shapes that i done was sucks....
I already tryed to use, loft, revolve, sweep, make two shapes and combine it thogeter....but whitout any good result! this pear shapes and this concave-convex internal belly is very hard to get....
1st try1st try2nd try2nd try
Can you guys say me hows the best way to do that(for dummyes) or send me some videos, thats will gonna help me a lot?
PS. I just trying to made the front part of motor, cause the middle and back parts i know that i can do!
3 REPLIES 3
If all the curvature changes are necessary on the rim, you can a loft across multiple planes, tightly packed to get the detail in that rim. Otherwise, a mixture of fillets should do just fine. In fact, your models seem like pretty good approximations.
What exactly are you looking to closer approximate?
etfrench
I'm guessing the front of the motor is the one you're showing multiple images of?
If you used a sketch to extrude the body of the motor, then you may be able to use an offset of the outline to create the front. Add a fillet, then cut the reliefs for the machine screws.
Attaching your file to the thread will get you more detailed answers (File|Export|Archive files (*.f3d)).
ETFrench
chrisplyler
Something like this?
That's done by Lofting three profiles, with the first being the main perimeter, while the second and third are on offset planes and have that perimeter offset inside. And finally Filleting as required.
Technology Administrators
