Cant extrude cut a simple proile into body.
7 REPLIES 7
Message 1 of 8
caseymulder911
702 Views, 7 Replies
caseymulder911
I have a body, which I have thickened (using thicken command 2mm). I am simply trying to extruce cut a profile onto it to clear out the bottom of the model that I dont need. It is acting like it doesnt recognize that it is a body eligable to be cut.  I know Ive done this successfully several times before, but today it doesnt work. Any ideas?
7 REPLIES 7
Message 2 of 8
lichtzeichenanlage
One idea: Please attach your project and / or a screencast.
Message 3 of 8
caseymulder911
Hmmm. I included the screencast URL in the posting. Have to go back and see why it didn’t include.
Message 4 of 8
lichtzeichenanlage
You have to insert the screencast before you post your content.
Message 5 of 8
Message 6 of 8
davebYYPCU
in reply to: caseymulder911
davebYYPCU
Extrude cut needs body type of surface or solid, you don't have either.
if you thicken the Tspline, you can cut it, with the spline in Split body, or extrude cut the profile.
Might help....
Might help....
Message 7 of 8
laughingcreek
Being in DM mode, you have to convert the tpline to a Brep body before doing modeling type edits to it.  The convert command is in the utilities menu.
Message 8 of 8
caseymulder911
Thanks Laughingcreek.... That was it, converted to Brep and it worked. I'm still learning all the purposes of all the different bodies, solids, mesh, etc.......
