Cant access Fusion 360 keeps telling me to terms of service have not been agreed
MATTHEW_SORRENTINO
Message 1 of 9
MATTHEW_SORRENTINO
No idea where to go from here. Can not find terms of service and fusion 360 locks up after I click ok.
Replies (8)
Message 2 of 9
masa.minohara
Hi @MATTHEW_SORRENTINO,
I am sorry to hear that you are experiencing the issue. Is this your first time to start Fusion 360 or have you been using Fusion and suddenly started receiving this message? Could you try clean uninstall and re-install to see if that makes any difference? Also, could you attach a screenshot of the message?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 9
MATTHEW_SORRENTINO
Hi, Ive been using it for a while now about 3 weeks. I haven't tried a clean uninstall because im afraid to loose some work ive done offline. We were hit by Hurricane Matthew and ive been without internet for 4 days now. I have attached my screen shot. I got internet back today and this message popped up when I went to open Fusion 360.
Message 4 of 9
masa.minohara
Thank you for your response and the screenshot! Could you try the steps below and let me know if that helps?
Mac OS
  1. Close Fusion 360
  2. In Terminal, type the below command and press enter
    open ~/library/
  3. In the Subsequent Finder window (Macintosh HD > Users > %Profile% > Library), browse to
    ~/Library/Application Support/Autodesk/Web Services
    NOTE - if you are on a version from the Mac App Store, browse to:  ~/Library/Containers/com.autodesk.mas.fusion360/Data/Library/Application Support/Autodesk
  4. In the Web Services (or Autodesk for App Store) Directory, locate the LoginState.xml file
  5. Right click on LoginState.xml and select Move to Trash
  6. Restart Fusion 360
Windows
  1. Close Fusion 360
  2. In windows explorer browse to   %localappdata%\autodesk\web services
  3. In the Web Services directory, right lick on the LoginState.xml file and select delete
  4. Restart Fusion 360
Masanobu Minohara
Message 5 of 9
MATTHEW_SORRENTINO
Thank you that worked! Much appreciated!
Message 6 of 9
masa.minohara
No problem! Glad to hear that helped!
Masanobu Minohara
Message 7 of 9
beikeland
Tried to delete the file %localappdata%\autodesk\web services\LoginState.xml but it only resulted in a new error:
Message 8 of 9
kate.raskauskas
Hi @beikeland,
Welcome to the forum!
Let's get you up and running. If you manually access your application log files (this link shows where to locate them) and post them, I can take a look and get a better idea of what's going on. Usually this is related to proxy networks. Do you have any restrictions on your network, or are you on a home network? And has Fusion ever worked on that machine before?
Best,
Kate Raskauskas
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
Message 9 of 9
beikeland
Tried everything network related before posting as that was the indication. Going over the log files revealed my local time was somehow offset by 1 hour, unsure how/when that happened as Fusion 360 worked earlier the same day. Anyways, all good.
