Message 1 of 9
- Mute
- Permalink
- Report
No idea where to go from here. Can not find terms of service and fusion 360 locks up after I click ok.
I am sorry to hear that you are experiencing the issue. Is this your first time to start Fusion 360 or have you been using Fusion and suddenly started receiving this message? Could you try clean uninstall and re-install to see if that makes any difference? Also, could you attach a screenshot of the message?
Hi, Ive been using it for a while now about 3 weeks. I haven't tried a clean uninstall because im afraid to loose some work ive done offline. We were hit by Hurricane Matthew and ive been without internet for 4 days now. I have attached my screen shot. I got internet back today and this message popped up when I went to open Fusion 360.
Thank you for your response and the screenshot! Could you try the steps below and let me know if that helps?
Mac OS
Windows
Thank you that worked! Much appreciated!
No problem! Glad to hear that helped!
Tried to delete the file %localappdata%\autodesk\web services\LoginState.xml but it only resulted in a new error:
Hi @beikeland,
Welcome to the forum!
Let's get you up and running. If you manually access your application log files (this link shows where to locate them) and post them, I can take a look and get a better idea of what's going on. Usually this is related to proxy networks. Do you have any restrictions on your network, or are you on a home network? And has Fusion ever worked on that machine before?
Best,
Tried everything network related before posting as that was the indication. Going over the log files revealed my local time was somehow offset by 1 hour, unsure how/when that happened as Fusion 360 worked earlier the same day. Anyways, all good.
