Cannot raise to power and square root
danpayneuk
Message 1 of 20
danpayneuk
Hi
I am currently trying to set parameters for a some chain ring designs.
Inserting the required formulas has been fine until this one.
I try to add the following sqrt( F_ ^2) - (( 1.4 * dr )- p / 2 )^2
however due to F_ being another parameter it does not allow it to work.  If I change F_ so that it is a number then all works fine.
Is this something that can be fixed?
Replies (19)
Message 2 of 20
TheCADWhisperer
I do not see units handling in your equation.
Message 3 of 20
danpayneuk
I chose inches in the drop down menu.
I have also tried with no units in the drop down menu and neither worked
Message 4 of 20
TheCADWhisperer
You must take account of canceling out units in your equation - just like in HS Math class.
Message 5 of 20
TheCADWhisperer
Once you File>Export and then Attach your *.f3d file here - I can generate proper equation.
Here is one example.
Message 6 of 20
danpayneuk
Hi Please find attached the f3d file as requested. I am also having a further issue regarding parameters and constraints when it comes to altering them, but I will discuss that in another post, unless preferred to keep it all in one post. Many thanks
Message 7 of 20
JDMather
You have several errors in your construction. I recommend that you simplify the sketch to create only one tooth "valley" and then pattern feature rather than sketch. I recommend that you not create more than one entity at a time without fully defining your sketch at each and every step.
Message 8 of 20
JDMather
The Attached document refers to SolidWorks and an Excel Spreadsheet, but the sketch construction technique is absolutely identical. As I find time - I will try to create example in Fusion 360 using your parameters. Bottom line - 1. Constrain every single entity as you create it. 2. Sketch only one tooth.
Message 9 of 20
JDMather
Open the Attache file. Note that I create one entity - the Pitch Diameter and fully define it (turns black) and change to Construction (as it really is).
Message 10 of 20
JDMather
Next Roller Clearance. Note that sketch is fully constrained.
Message 11 of 20
danpayneuk
JDMather, thanks for your replies. I will look at the attached links and files. If I have any more questions I will come back to you. Thanks for for time looking at this.
Message 12 of 20
JDMather
Angle A Note that the sketch is fully constrained. See a trend going on here?
Message 13 of 20
JDMather
Angle B Note that sketch is fully constrained.
Message 14 of 20
JDMather
yz offset Note that the sketch is fully constrained.
Message 15 of 20
JDMather
W offset What do you notice about the sketch?
Message 16 of 20
JDMather
One tooth profile.
Message 17 of 20
JDMather
Pattern Feature is much more computationally efficient.
Message 18 of 20
danpayneuk
Wow thanks for all the updates. I have just been looking over them and especially the last showing the pattern feature. The main reason for the parametric modelling is so that I can change the number of teeth and the model automatically update correctly. It appears the one you have drawn has the same issues as what I was finding. If you change the tooth count (n) the model does not correctly remodel as would of hoped.
Message 19 of 20
JDMather
@danpayneuk wrote:
... If you change the tooth count (n) the model does not correctly remodel as would of hoped.
I didn't look at setting the number of teeth as parametric - I just typed in 16.
I will take a look tomorrow at setting the number of teeth parametric so that the part updates correctly.
Message 20 of 20
danpayneuk
Hi JDmather
Did you possibly look at the reason why when altering the N value the model does not rebuild correctly?
I have tried numerous things and if changing more than once, especially for example n=16 to n=36 and then back to n=16, the model does not rebuild correctly.
