Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Cannot Move Sketch Plane for Redefine Sketch Plane
7 REPLIES 7
Message 1 of 8
fsonnichsen
381 Views, 7 Replies
I cannot move a sketch plane using the "Redefine Sketch Plane" process.
I am trying to create 2 sketches, separated by a distance. Thus I can, for example, sketch 2 rectangles in 2 separate sketches on the XY plane. Now I want to separate these by a distance Z (in preparation for lofting).
>  I have right selected one of the sketches in the Browser and I see "redefine sketch plane"  in the dropdown.
>  I select this and get a pop-up asking me to select the sketch plane.
>  I show my "origin" and select the plane using the OK on the dropdown.
And that is it--I was expecting a panel to appear asking what Z offset I need but I don't see this. So I cannot offset the sketch/plane.
I looked about here and on the web but no cigar- Any help appreciated
thanks  Fritz
7 REPLIES 7
Message 2 of 8
etfrench
in reply to: fsonnichsen
Create an offset plane first, then redefine the sketch plane to the new plane.
ETFrench
Message 3 of 8
fsonnichsen
in reply to: etfrench
OK-i have a sketch and the first rectangle.
Now-per your instructions, I need to create an offset plane--how do I do this?
Message 4 of 8
etfrench
Just select one of the Origin planes and set the distance.
ETFrench
Message 5 of 8
jhackney1972
Please remember the sketch, you want to Redefine Sketch Plane, MUST exist after the Offset Plane you want to redefine to.
John Hackney, Retired
Message 6 of 8
fsonnichsen
OK. If I open an "origin" I see the several cartesian planes.
Clicking on the XY for example does nothing. But if I right click I can get a dropdown and select "offset plane".
This works but it creates a new plane-a construction plane-instead of offsetting the one that I am trying to move. From here I  an sketch on it and then create a loft with other sketches.
Is this the correct way to do it then-with a construction plane?
thanks
Fritz
Message 7 of 8
etfrench
Yes.  You need to create the destination plane first if one doesn't exist.  Note: You can also use planar faces on a body as the destination plane.
ETFrench
Message 8 of 8
TheCADWhisperer
@fsonnichsen
1. Drag Timeline Marker back in history before the sketch.
2. Create the Plane.
3. Roll the Timeline Marker forward and then right click on the sketch...
