Cannot move derived Sketch between Components
wolfgam
wolfgam
i have a body and i derived sketch.
Now i create a new component and move the body to the new component -> Works fine
I cannot move the derived sketch to the new component. When i drop it on the new component, the component gets grey, but nothings happens. The sketch remains at its origin position.
Why?
regards
Wolfgam
Now i Create a new component and move the object to the new component -> Works fine
I cannot move the derived sketch to the new component. The component gets grey when selected, but the sketch is not moved?! Why?
jhackney1972
If you want a Derived Sketch in an existing Component, why not just activate the Component and then Derive the sketch into it?  Then then sketch will be available to do as you desire and will be linked to the original sketch is you do not Break the Link between them.
John Hackney, Retired
wolfgam
Of course your are right. But when starting a project without a specific component (yes i know this is an error, never start without a component), you cannot move the derive the later created component....
jhackney1972
Yes you are correct you cannot drag (move) it into a Component.  Again, if you have a later component just Derive the same sketch in or a different one.  As you can see I have two Component and I have Derived a sketch, the same one here, into each.
