Cannot move an imported component from SketchUp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, novice here.
I downloaded a SketchUp file and got it into Fusion. I can add the component to a design and move it around - but after I finish, the component can never get moved again. Instead of the component moving as normal, the arrows move and the component remains behind.
- I am not in Direct modeling mode (history is on)
- There are no joints
- I tried Break Link, no effect
- Moving "normal" components works just fine.
The test design with just this component: https://a360.co/484XArl
The component (outside the design): https://a360.co/3ON2Gzu
I am able to move the individual bodies (4 iirc) but not the top level component/subcomponents.
I even tried making an "outer" component to contain the imported component, but I can't move that either.
Further, it prevents bodies (e.g. sphere) from moving as part of the outer component too. Deleting the problem component allows the bodies to move as normal.
Any suggestions?
