Cannot modify STL / all black after import
Hi, I'm new and trying to modify a STL model from thingiverse, seehttps://www.dropbox.com/s/jiyy5p8fy3e89un/Raspberry_Pi_DIN_Rail_Clip.stl?dl=0  or http://www.thingiverse.com/thing:513633/#files (the forum doesn't let you attach stl files)
I'm using the upload command and then insert and it shows up like this. From what I understand i should also be able to import it as a mesh and use the sculpt commands which doesn't work either. If you could point me in the right direction, this would be great.
This is on OSX.
I've been having a similar issue. though I can work with the STL it's difficult/impossible to see the surface features as it's all one flat colour. I found that converting the STL to an OBJ before importing helps - not sure if there is a more eloquent solution as I'm new to this as well.
San_Escobar
Simple at the feature tree just apply different material to the STL part. preferably something matte. I like to apply PEAK its a kind of cream plastic.
HTH, Enjoy.
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
