03:11 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, I'm new and trying to modify a STL model from thingiverse, seehttps://www.dropbox.com/s/jiyy5p8fy3e89un/Raspberry_Pi_DIN_Rail_Clip.stl?dl=0 or http://www.thingiverse.com/thing:513633/#files (the forum doesn't let you attach stl files)
I'm using the upload command and then insert and it shows up like this. From what I understand i should also be able to import it as a mesh and use the sculpt commands which doesn't work either. If you could point me in the right direction, this would be great.
This is on OSX.
