Cannot Join Bodies with Extrude
neljoshua
Advisor Advisor
Message 1 of 10
neljoshua
I am working on a simple model of our shop.  I created the floor and walls with a sketch and then proceeded to extrude features.  I attempted to use extrude-join, but for one of the features, this did not work.  Fusion instead created a new body--despite the fact that I selected "Join".  I tried editing the feature--same result.  I tried rolling the history marker back and editing the extrude feature--same result.  I tried deleting the feature and re-creating it--same result.  See the Screencast for the issue.
In order to move forward, I created a new component with the walls, but this is not what I would prefer to do.  The file can be found here.
Thanks in advance.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Replies (9)
Message 2 of 10
Beyondforce
Hi @neljoshua,
If you want combine two bodies, then you need to use the Combine tool! If you want to Join two bodies, then you need to use the Joint tool.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 10
neljoshua
@Beyondforce,
Thanks.  I know that this can be done after the body is created, but one can (or used to be able to) extrude-join without creating a body and then combining it afterward.  I typically use extrude-join if I am adding features to a body or component and combine if I am working with separate components.
I used the extrude-join tactic with other features in this model without any problems, but this one will not operate in that fashion.  I am not sure why it is not working with this one feature.
__
Message 4 of 10
Beyondforce
In order to join two bodies via Extrude, the bodies needs to touch each other!
Ben Korez
| YouTube
Message 5 of 10
neljoshua
@Beyondforce,
Those bodies do.  All of the "walls" in this model (and the floor as well) were created from one sketch.  If this was not the case, the other extrude-join features should have failed as well.
__
Message 6 of 10
Beyondforce
Will you please attach the file,so L can test it.
Ben Korez
| YouTube
Message 7 of 10
neljoshua
@Beyondforce,
It is in the original post; please let me know if the link does not work.
Thanks for your time.
__
Message 8 of 10
Beyondforce
Hi @neljoshua,
I figure out the problem. You forgot R.U.L.E #1!
You have created the Floor inside its own component and the other corner Body in the Root component. That's why you couldn't Join those two bodies, because they were placed on a different components! In this situation, the ONLY way to fix it, is to use the Combine tool, like I'm showing in the screencast.
For the next time, DON'T for get to follow R.U.L.E #1!
Cheers / Ben
Ben Korez
| YouTube
Message 9 of 10
neljoshua
@Beyondforce,
My mistake; thanks.
__
Message 10 of 10
Beyondforce
Just remember to follow R.U.L.E #1 and everything will be ok 😉
Ben Korez
| YouTube
