& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
Not sure why - I am usually able to use these tools without a problem.
But here, no matter how I try, I can never select the profile I want to extrude. I click and click in different places and it just remains unselected, with no indication as to why it cannot be selected.
The blue item is a loft object. Is there any reason why I cannot Extrude or Press/Pull a lofted object?
How can I achieve the same result?
Having just read your previous thread about sketch objects, this one tends to suggest the selection settings may not be as expected.
Press pull on a face, creates the offset result, but not sure you can do it to a feature, to move the loft feature as if being push pulled, I am thinking it would have to be scaled.
i would check you selection button, top right if menu, near the end, see what is ticked there, and when going to sketches, check again.
might help.
Hi @lindsay.fowler,
This is why...
To fix this, you need to Right Click on the Bodies folder and choose "Selectable/Unselectable"
Cheers / Ben
Check out my YouTube channel: Fusion 360: NewbiesPlus
Ben Korez
Owner, TESREG.com & Fusion 360 NewbiesPlus
TESREG - Fusion 360 Hardware Benchmark
Facebook | YouTube
That's a new one on me; what's it for?
This seems to only apply to a particular Bodies folder; I made them Unselectable but when I opened the selection filter bodies was still checked.
Ben Korez
Facebook | YouTube
Yes, that would be useful; thanks
Kudos to you Sir @Beyondforce, I was excited that you had solved my problem, but unfortunately this is not the solution...
As you can see, I have now made the folder selectable, but I still cannot select the profile (little rectangle at the end of the tool).
Ben Korez
Facebook | YouTube
Certainly. Thank you.
File looks fine, maybe the case is that you like to extrude non-planar faces, but you should be able to offset them:
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
