Lofting between a pipe and a coil
Message 1 of 12
I'm trying to model a wire that is bent into a coil at one end. In the screen shot below you can see I have created a coil and a pipe as 2 separate bodies and now I want to join them by connecting/lofting between the highlighted faces. The connection needs to be smooth like a spline to continue the flow of the wire. I can't sketch a spline between the two faces easily because they don't align on a 2d plane. How would one make this connection successfully? Thanks.screen2.PNG
Replies (11)
Message 2 of 12
Use Loft between 2 ends and just set "Tangent" attribute for both profiles in Loft dialog window. Also you can play with Tangency weight.
Message 3 of 12
TheCADWhisperer
Message 4 of 12
That's very close to what I need, but when I do it the connection does not maintain the round profile. I'll upload my .f3dscreen3.PNG
Message 5 of 12
.f3d attached.
Message 6 of 12
Then you have to draw 3d-spline touching both ends and use it as a center line for Loft operation. the result is attached.
Message 7 of 12
Thanks grandag. That method is the best option I have so far. Annoyingly even with the tangent constraints on the sketch the transition is not totally smooth and you get a visible kink where the two bodies meet (see below). Perhaps there is a better approach than creating the coil and the pipe as separate bodies and trying to link them?
Message 8 of 12
If both ends have identical profiles you can use Sweep along the same center line instead of Loft. It could provide better result on turns.
Message 9 of 12
Thanks grandag. Sweeping does make it a little smoother although still not perfect. This works for me but I still feel like perhaps I'm approaching this the wrong way. By creating the coil and the pipe and joining them this way the design intent is not captured well. For instance, if I adjust the diameter of the coil feature then nothing lines up (see bellow). It doesn't feel like a good way to model a single wire that is bent into a complex shape.
Message 10 of 12
michallach81
Michał Lach
Designer
co-author
projektowanieproduktow.wordpress.com
Message 11 of 12
Wow. Thanks @michallach81 that is a really clever way to solve the problem. I never thought of using a triangular loft to create a spline in the center of the coil like that. However, it still very much feels like a workaround to me. In the end, we have an extra coil feature that is not part of the model and we cant remove it because it is included into the sketch. It just seems like there should be a cleaner way to make a shape like this. Perhaps Fusion just doesn't have the feature I'm looking for. In which case this is probably the best solution. Thanks.
Message 12 of 12
michallach81
RMB on that coil body in the browser and you will see an option to delete and remove. Delete will mess your file while remove will leave everything intact except unwanted coil.
Michał Lach
Designer
co-author
