03:07 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Im currently experiencing a problem with the fusion 360 Hub when exporting versions. Whenever I export a version of a design that is not the top or current promoted design, it always fails, no matter what. Only when you promote that version to the top of your versions and then export, does it then successfully export as an STL. I realise this has an easy fix by just promoting the version, but there is still an inherent problem somewhere that you/I cannot export unpromoted versions even though the functionality is built in.
