- Mute
- Permalink
- Report
Hola -
I designed a generic rack-mount enclosure, and now I want to use it as the base model for a few variations with different panel cutouts. The process I've tried:
- make a new design file
- insert the generic enclosure in as a linked assembly
- draw a sketch with the panel cutout shapes
- try to extrude cut into the linked panel component
Trying to do this gives "Error: No target body found to cut or intersect!"
A couple other things I've noticed
- There is no issue cutting through components that were made in the new linking model
- Trying to break the link with the base model gives "Error: Break link fails due to cycle link or other reason!"
Any help is appreciated!
