CANNOT CREATE SHELL
CANNOT CREATE SHELL
KhaiE
CANNOT CREATE SHELL
KhaiE
  I have created a body, split the body, and created separate components of each. I shell the right right side to 3.5mm no problem, but the left side wont shell more than 2.6mm or i get this error (see attachment). Both components are symetrical.
Beyondforce
Hi @KhaiE,
Will you please attach the file, I would like to test it.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
HughesTooling
@KhaiE you could try shelling the part before splitting, it might give you an idea where the problem is. To shell before splitting you need to select the body from the browser or window select if you have select through enabled.
Mark
Edit. Missed the bit about the 2 halves bing symmetrical. Shelling first might be a workaround but it would be helpful if you can share the design to find a fix for the problem you're having.
Mark Hughes
Owner, Hughes Tooling
