Cannot create components from bodies
lesUZTMG
Message 1 of 15
lesUZTMG
Rt-clicking a body brings up a short list of items which does not include "create components from bodies".
The items shown are: Create selection set, Configure, Properties, Save as mesh, Copy, Show/Hide, Isolate,  and Find in Window.  Why isn't the expected menu list displayed?
This design was opened from the Data Panel.
Replies (14)
Message 2 of 15
jhackney1972
Please capture a screen image showing the Browser, the body you are right clicking on and the resulting context menu.  This will help the Forum users diagnosis your issue.
John Hackney, Retired
Message 3 of 15
jhackney1972
I did not see where you have posted a screen capture to show what you are seeing so I will attach one of my own to show you the command is indeed there.
Message 4 of 15
lesUZTMG
I did post a screen shot but perhaps I didn't do it correctly.  Here it is.
Message 5 of 15
jcook27FELS3
John. I have a similar situation as was shown in your screen capture. I created a sketch and extruded to a body. So I am at the same point as in your picture. When I select Create Components from Body a component is created and the body is inside, as expected. However the sketch associated with the body does not move under the newly created component. The sketch is 'above' the new component in the hierarchy. What did I do wrong?
Message 6 of 15
Ajay_Kumar_Reddy
Hi!
1. Create a component
2. Drag the sketch of the newly created component
Then the sketch and body will come under the newly created component.
Message 7 of 15
jcook27FELS3
that doesnt work
Create new coponent expects a body to be selected. if you dont jhave a body selected it will not allow component creation.
Message 8 of 15
Ajay_Kumar_Reddy
There are two ways in which you can create a component without involving a body.
1. You can right click on file name in the browser (untitled) and select create component
2. Using create menu you can create a new component
Message 9 of 15
rouchi_sf
Observer
Observer
after the last update work with components became a total caos!
Message 10 of 15
TheCADWhisperer
@rouchi_sf
It is the same as it has always been.
Simply toggle to Hybrid if you want the old behavior.
Message 11 of 15
baron_von_richthofen_1974
Community Visitor
Community Visitor
I have the same problem. There is no create component option anymore. And when I started the project I asked for Hybrid. Ho wdo I know its hybrid and where can I find teh option to change it?
Message 12 of 15
g-andresen
take a look at Intent driven design
and several posts
günther
Message 13 of 15
zach_urrutia
Community Visitor
Community Visitor
Having a similar issue. Has anyone found a fix or workaround?
Message 14 of 15
g-andresen
Your description has no relation to the topic of this thread, but rather to the recently introduced system of intent-driven design.
There are now various posts on this topic with instructions on how to select the “Hybrid” option in the preferences, for example, or how to switch between options inside active designs.
günther
Message 15 of 15
TheCADWhisperer
@baron_von_richthofen_1974 wrote:
 How do I know its hybrid and where can I find the option to change it?
@zach_urrutia
