Cannot Create a Copy of a File
neljoshua
Advisor Advisor
Message 1 of 9
neljoshua
I am attempting to copy a file to begin work on a new design.  Fusion will begin to show the copy (graphical placeholder in the folder and a spinning disc), but it will not copy the file.
Is anyone else experiencing this?
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Replies (8)
Message 2 of 9
matt.pooley
Hi Josh,
I'm not sure what is causing this copy to fail, could you send your diagnostic log files to me (or post here) so we can investigate further.
Matt Pooley
On Behalf of the Fusion Dev Team
Message 3 of 9
matt.pooley
Apologies, just realized that I missed my email address, you can send the logs to me at matt.pooley@autodesk.com.
Matt.
Message 4 of 9
neljoshua
Matt,
Thanks for the reply.  The diagnostics are attached.
__
Message 5 of 9
matt.pooley
Hi Josh,
Unfortunately I wasn't able to spot any relevant errors in the logs and I haven't yet been able to find any related problems in our server side logs. Does the problem continue for you now ? (Does it still fail if you try to copy again). If it does, would you be willing to invite me to the relevant project temporarily so I can investigate further ?
I will also continue to look at our server logs and broaden the search to hopefully find more information.
Matt.
Message 6 of 9
mfeathers
When I get this (more often than I'd like), I just open the file I'd like to copy and do a Save As from the menu.
Message 7 of 9
matt.pooley
I did manage to reproduce this issue, the trigger for me appeared to be increasing model size to 40Mb+ and then mixing saving of new versions with attempts to Copy.
Now that I can reproduce, we will hopefully be able to track the issue down.
Matt.
Message 8 of 9
matt.pooley
Hi Josh,
We investigated what was happening here and found a problem with one of our services which was timing out when copying designs larger than a specific size. This problem has been resolved, and my test is succeeding. Could you confirm whether you are still seeing issues ?
Matt.
Message 9 of 9
neljoshua
All appears to be working now.
Thanks.
__
