cannot chamfer multiple screw holes - geometric configuration too complex
wolfgam
wolfgam
i am trying to chamfer 4 screw holes in an object. When selecting the edges and chamfer i get an error:
Geometric configuration too complex.
Why?
Wolfgang
TheCADWhisperer
Are the threaded holes?
If so, change to Cosmetic.
Add Chamfers.
Change back to Modeled.
File>Export and then Attach your *.f3d file here if you can't figure it out.
wolfgam
No, no threaded holes.
See attached .f3d file.
Wolfgang
TheCADWhisperer
I see multiple errors in your design?
Here is one example.
And another example -
wolfgam
Thank you!
Interesting - i entered for testing purposes a box design i used in onshape 1:1 to Fusion 360.
Result: Shell works different
With the same construction steps and the same dimensions i do not get the same result. To be more precise in Fusion 360 i produce errors....
Thank you for your help.
Wolfgang
